The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
450.3(C)
by Tesla
10 minutes 5 seconds ago
100AMP panel in 60 degree ambient what size wire?
by sidmuer
Today at 09:25 AM
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
05/21/12 11:37 PM
Housekeeping and Clean-up
by renosteinke
05/21/12 12:52 PM
Back to back bends on electric bender
by Tesla
05/20/12 05:38 PM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
gfretwell 27
HotLine1 27
sparkyinak 17
twh 15
renosteinke 14
Classified Ads:
Electrical-Classifieds.com
Who's Online
2 registered (Tesla, tbone), 124 Guests and 2 Spiders online.
Topic Options
Rate This Topic
#193159 - 03/20/10 12:39 PM Old subject question
George Little Offline
Loc: Michigan USA
I know this is an old subject but I wonder if anyone has information on the installation of a receptacle with ground terminal up. I am not aware of anything in the NEC but there seems to be a policy of installing "ground prong up" in hospitals. Is there something in the hospital code that specifies this requirement?
_________________________
George Little
Top
#193163 - 03/20/10 02:54 PM Re: Old subject question [Re: George Little]
HotLine1 Offline
Loc: Brick, NJ USA
George:
The logic is if a metal cover were to come into contact with a non-fully inserted plug, with ground 'up' there is no 'big flash'!
As to a code requirement, research will be required.
Top
#193165 - 03/20/10 03:08 PM Re: Old subject question [Re: HotLine1]
Loc: Michigan USA
John, I am familiar with that logic but can't really support it even slightly. I've been an electrician all my adult life and I'm 70 years old and I've never heard of that happening. Too far fetched for me. I just thought there would be some architect or engineer monitoring this board and they might have some NFPA or other standard that is used at the design phase of their specs.
George Little
Top
#193166 - 03/20/10 03:53 PM Re: Old subject question [Re: George Little]
EV607797 Offline
Loc: Springfield, VA, USA
Well, while we are at it: What about horizontal mounting requirements in the Chicago area? I still haven't found a legitimate reason for that.
---Ed---
Top
#193169 - 03/20/10 06:35 PM Re: Old subject question [Re: EV607797]
Loc: Michigan USA
At least with the horizontal mount and the grounded conductor blade up, you would not have a "big flash" like you still could if the ground blade were up. It's believable that the plate could still come in contact with the ground blade and the ungrounded blade with the ground blade in the up position. Assuming that the logic for mounting the receptacle in the ground up position to avoid the "big flash".
Come on hospital people what's the reason for mounting the receptacle in the "ground up" position.
Hey Fretwell- let's hear from ya.
Edited by George Little (03/20/10 06:36 PM)
George Little
Top
#193172 - 03/20/10 07:46 PM Re: Old subject question [Re: George Little]
WESTUPLACE Offline
Loc: Kingwood, TX USA
Although I know of no NEMA standards or requirements, it seams most commercial equipment like soda machines, ice makers and large coffee pots that have a right angle plug have a ground pin up configuration. Most home equipment like refrig. and window AC have Ground pin down. I have some hospital grade IEC cords with a right angle plug and they are ground pin up.
Top
#193177 - 03/20/10 07:53 PM Re: Old subject question [Re: WESTUPLACE]
Rewire Offline
Loc: Missouri
It was in the specs to put the ground up in the last hospital addition we did
Top
#193193 - 03/20/10 09:01 PM Re: Old subject question [Re: Rewire]
gfretwell Offline
Loc: Estero,Fl,usa
We just killed a thread for the same question didn't we? wink
but I am officially in the "it makes no difference category".
Typically I see people turning the switched receptacles upside down from the others as an aid to identifying them later.
The only time it does seem to matter is when you have a right angle molded plug. I have examples of cords that come out each way though and my UPS cords seem to come out at 45 degrees (so you can get 2 in a duplex I suppose.)
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
