The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Page 2 of 2 < 1 2
Topic Options
Rate This Topic
#192544 - 02/16/10 10:39 PM Re: Watch them old sockets!! (NZ) [Re: HotLine1]
Trumpy Offline
Loc: SI,New Zealand
Originally Posted By: HotLine1
I have to ask, is the earth contact a single piece with spring tension, or is it two pieces, like two "L"'s that are held in place by a stud under that nice termination lug?
Or, is your earth pin much wider than the other pins on the male cap?
John,
One side of the contact is brass, the other side is copper.
Usually there is quite a bit of "spring tension" between the two contacts, that holds the pin of the plug in place.
As far as I'm aware, the pins are all the same size, it's just that the earth is longer.
_________________________
Let's face it, these days if you're not young, you're old - Red Green grin
Top
#192561 - 02/17/10 05:47 PM Re: Watch them old sockets!! (NZ) [Re: Trumpy]
HotLine1 Offline
Loc: Brick, NJ USA
Thanks Mike! It's kind of hard to tell from the pic, but I got it now.
Top
Page 2 of 2 < 1 2
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
