Tex, there are still a lot of unconverted non-metric things, as you say.
The Revolutionaires did try a 10 hour clock, [1793-1806] but it proved short lived.
click to enlarge
They also had three 10-day weeks in each of the renamed the
12 months- [
another twelvism that survived]! This caused riots when the
sans-culottes realised they'd just lost their weekends off!
They got round the inconvenience of the Earth continuing to rotate at the same speed after 1793 by slotting in 6 or 7 special days at the end of the months.
There are a few more. The old pre-revolutionary pipe threads have not changed - metric pipe threads are in fact interchangeable with BSP for domestic work. Funnily enough, the American National Pipe threads are not interchangeable even though dimensioned in inches. I wonder if it was the cost of replacing all the French plumbers' taps and dies? As a lad in the machine-shop, all our lathes had a 127-tooth wheel for screwcutting [nearly] true metric pitch threads on British machines.
'G' as you say refused to be neat and tidy, insisting on accelerating at 9.81m/sec2 or about 32 ft/sec2. As a matter of fact the
poundal and
slug, engineering calculation units based on Earth's 'G' cannot be termed
Imperial, for they were invented long after the 1824 Act.
And finally Gold. Still traded in ounces, troy of course. At
12 ounces to the pound!
