The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
4" PVC Conduit For Sale - Chicago
by acastillo
05/23/12 01:12 PM
4" PVC Conduit For Sale In Chicago
by acastillo
05/23/12 01:12 PM
100AMP panel in 60 degree ambient what size wire?
by sidmuer
05/23/12 09:25 AM
450.3(C)
by gfretwell
05/22/12 09:32 PM
One Doorbell Button to 4 Doorbells/Chimes
by sparkyinak
05/21/12 11:37 PM
An old Amprobe model 550
Shout Box
Top Posters (30 Days)
HotLine1 27
gfretwell 27
sparkyinak 17
twh 15
renosteinke 14
Classified Ads:
Electrical-Classifieds.com
Who's Online
1 registered (acastillo), 111 Guests and 6 Spiders online.
Page 1 of 2 1 2 >
Topic Options
Rate This Topic
#192259 - 02/03/10 05:38 PM GFCI breaker vs recepticle for 210.8a
Haligan Offline
Loc: Berkeley, CA USA
Both are permissible, so how to decide?
With the breaker it's more of a hassle to run to the panel to reset, especially if it's at a distance, even more so if you're wet and naked.
But I can't remember the last time I've seen a GFCI trip.
opinions anyone?
Top
#192261 - 02/03/10 06:00 PM Re: GFCI breaker vs recepticle for 210.8a [Re: Haligan]
HotLine1 Online   content
Loc: Brick, NJ USA
IMHO, it's a design issue, as both are NEC compliant. Also, it's a convenience thing, as you said regarding running and wet.
As to tripping, the one for my laundry circuit tripped a few weeks back...reason unknown. As an inspector, I 'trip' quite a few each day (hopefully).
A personal opinion of mine is a few McMansions that have a GFI in the powder room (first floor) that runs thru to a few other baths. But, that's a design issue!
_________________________
Top
#192271 - 02/04/10 08:34 AM Re: GFCI breaker vs recepticle for 210.8a [Re: HotLine1]
ghost307 Offline
Loc: Chicago Illinois USA
The problem that I see with chaining GFI receptacles in several bathrooms is that inevitably someone will be using the bathroom that the reset button is in while I'm wet and naked in the corridor banging on the door because the bathroom that I was in is downstream of it.
"Murphy was an optimist"
Ghost307
Top
#192290 - 02/05/10 03:26 PM Re: GFCI breaker vs recepticle for 210.8a [Re: ghost307]
Rewire Offline
Loc: Missouri
A GFI receptacle is alot less cost than a GFI breaker.Although legal by code I would never recommend daisy chaining bath recepts.The last custom we did actually had two circuits for the master bath receptacles.
Top
#192291 - 02/05/10 04:14 PM Re: GFCI breaker vs recepticle for 210.8a [Re: Rewire]
Haligan Offline
It's a tiny bathroom. 1 sink. I'm only putting 2 receps for convenience. They'll be the only things on the dedicated 20a, and I'm wiring them in parallel.
The 20a gfci breaker is already in the panel from somebody before me.
I've made it clear the penalty for dropping the hairdryer in the toilet is having to run up a flight of stairs into the garage to reset the GFCI. not to mention buying a new hairdryer plus a little .5 amp zinger.
or is it .05. Or is that DUI?
Top
#192294 - 02/05/10 06:06 PM Re: GFCI breaker vs recepticle for 210.8a [Re: Haligan]
Rewire Offline
Loc: Missouri
The funny thing is dropping the hairdryer in the toilet wont trip the GFI.
Top
#192320 - 02/06/10 07:50 PM Re: GFCI breaker vs recepticle for 210.8a [Re: Haligan]
resqcapt19 Offline
Loc: IL
I've made it clear the penalty for dropping the hairdryer in the toilet is having to run up a flight of stairs into the garage to reset the GFCI. ...
I would not expect it to trip the GFCI as I have never seen a hair dryer with a 3 wire cord. In the absence of an EGC in the hair dryer cord, there is no current path other than hot to neutral when you drop it into the toilet.
Top
#192324 - 02/07/10 09:43 AM Re: GFCI breaker vs recepticle for 210.8a [Re: resqcapt19]
gfretwell Offline
Loc: Estero,Fl,usa
It should still trip the immersion detector in the plug. There is a 3 wire cord in a hair dryer but the 3d wire just connects to a ring in the barrel of the dryer. It is similar to a GFCI but it is looking for any current in that 3d wire from either line side conductor.
Top
#192330 - 02/08/10 07:11 AM Re: GFCI breaker vs recepticle for 210.8a [Re: gfretwell]
resqcapt19 Offline
Loc: IL
Yes, that is the purpose of the immersion detector, I was talking about the branch circuit GFCI protection. It is very unlikely that a two wire device will trip the branch circuit GFCI when the device is dropped in a toilet....unless the toilet is an all metal one like found in prisions.
Top
#192344 - 02/09/10 07:52 AM Re: GFCI breaker vs recepticle for 210.8a [Re: resqcapt19]
sparky Offline
as an aside here, if one does opt for a panel GFI breaker, and daisychain all the non-dedicated gfci required receptacles back to it, doesn't the length of said circuit's R factor start to influence that 5ma?
~S~
Top
Page 1 of 2 1 2 >
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
