#191840 - 01/15/10 12:43 PM
NY State Carbon Monoxide Alarm Requirements
Loc: NY, USA
Amanda’s Law Carbon monoxide alarm requirements to go into effect February 22, 2010As the result of legislation, Amanda’s Law will go into effect on February 22, 2010. It requires essentially all residences, both new and existing, to have carbon monoxide alarms installed. The specific requirements differ for new and existing residences and also on when the buildings were built and subcategories of occupancy groups. Probably the most asked question will be the requirement for existing one and two family residences. They will be required to have one carbon monoxide alarm installed on the lowest story having a sleeping area. The proposal to modify the Uniform Fire Prevention and Building Code, in order to comply with Amanda's Law, is in the process of being adopted as an emergency rule. The following link provides the proposed code text and legislation, Amanda’s Law. http://www.dos.state.ny.us/code/COAlarm.htm
Top
#191881 - 01/17/10 01:46 AM
Re: NY State Carbon Monoxide Alarm Requirements
[Re: Trumpy]
Loc: Estero,Fl,usa
The Florida CO detector statute says any dwelling with an attached garage, fossil fuel appliance or fire place. That pretty much sums up the fear. They also recommend a CO detector for anyone with a portable generator.
_________________________
Top
#191882 - 01/17/10 02:48 AM
[Re: gfretwell]
Loc: SI,New Zealand
Fear of what? CO is a very dangerous gas, it is silent in it's movement, it moves from the ground up, it excludes oxygen to three parts of itself. It will put you to sleep before it kills you.
Let's face it, these days if you're not young, you're old - Red Green
Top
#191889 - 01/17/10 10:15 AM
[Re: Trumpy]
Loc: Lowell area, Ma. USA
Top
#191890 - 01/17/10 10:20 AM
[Re: Trumpy]
Loc: Estero,Fl,usa
I suppose that is what they call a rhetorical question  You answered it, anyway. Since we have so many houses that don't really have a source of CO (all electric, no fireplace, no garage) they worded the law to acknowledge that. Unfortunately the biggest cause of CO poisoning is people running their generator near an open window or in the garage after a hurricane. They want it where they can keep an eye on it so someone won't steal it. I had to hollar at my ex wife about the same thing. She told me she bought a generator and was planning on running it in the garage. I warned her about the danger and reminded her there was a steel ring cast in the brick wall next to the driveway (for my motorcycle) that she could use to chain it up outside. I had left a 3/8" hardened chain and a high security padlock on the wall in the garage.
Top
#191893 - 01/17/10 01:12 PM
[Re: gfretwell]
Loc: Blue Collar Country
Responding to Mike's question ....
The CO laws are introduced with good intentions. It is ironic that one of the primary causes of CO in the house these days is the direct result of other well-intentioned requlations. Indeed, these 'unexpected consequences' are one reason I am so adamant about restricting the role of regulation in our lives.
In the late '70's, the 'energy crisis' led to folks taking extreme measures to seal their homes in an effort to reduce their heating bills. This emphasis is carried on today in the latest spate of 'energy' regulations ("cash for caulkers") and the LEED program. There are even firms that pressure-test buildings for leaks.
The caulking madness of the '70's was followed by the 'toxic mold' issue of the '80's. This led to a renewed emphasis on bath fans, kitchen exhaust fans, and such. The "Mechanical" code upped it's requirements for exhaust air.
Does anyone see the problem yet?
When you try to pull air out of a sealed house, you create a vacuum. This in turn results in the flow from your various flue pipes to reverse. In order for the fresh air to enter, first the exhaust gasses have to be pulled into the house. Voila! CO problems.
How bad can this be? I've seen one job where this back-draft was strong enough to prevent a commercial gas water heater from fully igniting, even though the flue was both large and straight- and this was with a fully open door between the water heater and the exhaust fan! In this instance, the 'exhaust fan' was the air conditioning system.
So, Mike ... consider that under today's construction practices you can have a CO problem precisely because everything is working 'right.' With the current political emphasis on sealing your home, expect the problem to worsen.
Top
#191898 - 01/17/10 02:23 PM
[Re: renosteinke]
John, For older systems true. The newer systems all require a make up air source. Ironic: seal the house up tight,then install exhaust! Ummm,I'm no engineer but... aint that as bad as a leaky window?
Top
#191962 - 01/21/10 12:16 PM
[Re: leland]
Loc: Chesapeake, VA
It pretty much implies leaky windows, otherwise the house would become a vacuum and everyone in it would suffocate.
Toxic fumes from paint and cleaning products, etc are a similar issue- they just get circulated forever.
The "right" solution would be to mandate fresh air ventilation be incorporated into home HVAC systems like they do in commercial designs. So, you turn on an exhaust fan, you draw in fresh outside air through the HVAC system that conditions it before dumping it into the house, etc. Nobody wants to do this because it's sounds like you're wasting energy, but it's just one of those things you need to do to prevent a sick home.
Top
#191977 - 01/22/10 12:38 AM
[Re: renosteinke]
Loc: Estero,Fl,usa
I got pretty heavily involved in energy saving in the last oil crisis (Carter days). The trick with fresh air makeup is a heat exchanger that scavenges the heat from the air going one way and transfers it to the air going the other way. Granted you only save half the energy as a theoretical max but that is better than zero. In reality the efficiency of most heat exchangers you might have in a dwelling wasn't worth the expense and hassle but I have seen it done in big commercial fairly successfully. The National Geographic building in Germantown Md heat exchanged everything and used water as a transfer and storage medium. They ended up with so much excess heat from normal building loads they could keep the building warm and still had enough left over to keep the lake out front from freezing.
Top
#192177 - 01/30/10 04:58 PM
[Re: renosteinke]
Loc: va
Gas logs dont really know they made vented and unvented systems .my house has a co detector in the living room where the gas logs are good idea.How long will it be before they put that in the NEC for houses
Top
#192184 - 01/31/10 09:15 AM
[Re: mikeD]
"in the living room"
You've hit on one of my primary objections to mandating CO detectors: placement.
There's no settled doctrine as to the placement of CO detectors. The NFPA standard, after a lot of doubletalk, refers you back to the manufacturers' instructions. The instructions ... well, summarised simply, do not find a problem with any placement you might suggest.
Part of the problem lies in the nature of CO. It's not much different, in density or temperature, from the surrounding air. There is no compelling reasom to place it in any particular location.
The other problem lies in the way CO affects our bodies - and, by extension, the way detectors are designed to operate. The less CO that is present, the longer they take to to go into alarm. This is quite different from a smoke detector, which won't ever go into alarm until a specific level is reached. It's also why having a CO detector with a readable display is a good idea, and why there is such an advantage to the corded units. Just like with the "Valentine One" radar detector ads say: there's no way for a battery unit to perform as well as a corded unit.
Getting back to 'the problem.' The sensing elements can be fooled. Instructions often illustrate placing one in the mechanicals closet, for example. The problem here is that the initial plume of CO or even hot air from an appliance igniting can create a false alarm. Likewise, gas fumes can set it off. So, that initial puff of gas before the igniter strikes, and the momentary flare of a poorly burning flame, can set off the detector - even though no hazard is present. IMO, you don't want these alarms anywhere near the appliances.
As others have pointed out, we percieve sleep time as the time where we are most at risk from this 'silent killer.' With that in mind, I DON'T want the detector outside the sleeping area. Simply closing the door can create a situation where the air in one room differs from the air in the next. I want that alarm near my sleeping head - but that's my opinion, and IMO a design matter.
As far as the requirement ever being added to the NEC goes, I doubt that will ever happen. As with smoke alarms, you'll find these requirements in the 'other' codes. Copies of the IBC, IRC, IMC, etc., can be found at BulkResource.Org . You need to know more than just 'your' code.
Top
#192188 - 01/31/10 12:56 PM
[Re: renosteinke]
Loc: Estero,Fl,usa
I was almost killed in a friend's house a few times because of a bad furnace. I used to sleep over there and I noticed I woke up with a hangover (for a lack of a better term) and I noticed a bad taste in my mouth a few times. I was just a kid but I always suspected it was an air quality problem. I started sleeping near an open window when I was there even in the winter. They had the furnace serviced some time later and the "gas man" condemned it because he had a cracked heat exchanger.
I have a hard time describing what CO poisoning feels like but I will never forget it. It is like you are breathing cotton or something. Your lungs are taking in air but it isn't working for you. I am pretty happy that I am "all electric" here.
Top
