by NORCAL - 03/19/24 05:11 PM
0 members (), 248 guests, and 16 robots.
[Linked Image from users.stargate.net]
Unfortunately, it wasn't related to the problem I was troubleshooting...
-Virgil
5 Star Inspections
Member IAEI
[Linked Image] [Linked Image] [Linked Image]
This was live????
Peter
sparky66,I thought I had seen it all, until this.Ive seen zip cord but never phone wire.
As you can see from the pictures, CAT3 is good for 20A 125V. You MUST use CAT5 on 30A circuits!
WOW [Linked Image]
The amazing thing is that the wire doesn't appear to be burned up. I guess that nothing larger than a table lamp was ever plugged in here.
I saw thermostat wire used like this once, but even that is heavier than phone wire. [Linked Image]
Isn't bell/phone wire the same gauge as the wire used for the miniature X-mas tree lights?
Of course those are wired in series so there's probably not that much juice going through them.
Sparky66 - That's a venerable and interesting-looking switch. Neve seen an in-wall switch with front wire terminals before. I'd be leery about using one of those with a metal cover-plate. [Linked Image]
Did you put new wire/devices in there or did you have to close it back and leave as-is?
Amazin...
never seen nuthin like it.
Hope you edumacated the homeowner that he should use RED and GREEN as tip & ring!!
Maybe da plug went bad on his phone and he put male plug on and used rec. to plug phone in, switch was to shut the dang thang off at suppertime so as not to be interrupted by danged telemarketers.
Glenn (former ingeesh teacher)
<paul harvey>
"...and now, the rest of the story..."
</paul harvey>
This is the same dwelling as the one in these threads:
Link 1
Link 2
This was found, as well as three flying and hidden splices, and other loveliness. Still no fault found. The AFCI trips when load is applied, and taking the circuit apart piece by piece today had narrowed it down to a splice I can't reach without liberal use of a Sawzall.
So... We'll tackle it again tomorrow...
Oh, this receptacle and switch is/was in a bathroom. Yes, a bathroom. The most abused receptacle in a house. My belief is that it must've never been energized, or atleast never loaded. The "feeder" was snipped off in the wall. I tore boxes and all out and threw them in the trash.
All in a days work.
<paul harvey>
"...Good day..."
</paul harvey>
-Virgil
5 Star Inspections
Member IAEI
Woops... I did the <paul harvey> thing already in the other thread!
[This message has been edited by sparky66wv (edited 12-20-2002).]
-Virgil
5 Star Inspections
Member IAEI
