161
30
Posts: 3,682 Likes: 3
Administrator Member
While trying to run a new circuit I found this splice in a dropped ceiling. Plastic wall anchors instead of wire nuts. Oh yeah, also spliced out of the box with no cover, etc., etc.. Plastic doesn't conduct electricity, right?
Damn electricians and their expensive wire nuts. It'll be fine. I'll even give you my, "outta sight" guarantee! Guaranteed until I'm out of sight.
Peter Coleman
I really want to thank you for this pic ... I had encountered this once myself (except the wall anchors were yellow, and it was inside a box) ... but I failed to get a picture. As a result, there were floks who doubted that anyone would actually do this ...
They're too expensive if you use a Vise-Grip for each :-) /mike
Not to mention that there's a perfectly good connector in the side of the box. Were they just trying to see how many violations they could commit in one operation?
---Ed---
This wasn't a total f-up. The red lead was also hot and covered by a wall anchor.
They're too expensive if you use a Vise-Grip for each :-) Actually, If you use the smaller size of Vice-Grips..........
I don't expect those wall anchors to do much
I have a sense of adventure, I just keep it leashed with common sense.
Respect, that's a new one!
The wall anchors are probably supposed to cover the twisted wires...
