bigpapa Offline OP
What does this term mean when referring to telephone cabling?
Never heard of it and I'm in the phone business. Sounds like maybe someone trying to describe ISDN-BRI or DSL. Either way, it just uses standard twisted pair wiring, CAT3 is more than sufficient for these services.
---Ed---
Sounds like a "pair gain" term.
Read some stuff about it here: http://en.wikipedia.org/wiki/Pair_gain
They don't mention a "DAML" which I've run across. I'd guess it's a Digital multiplexor. Basically you get one pair from the CO, and it gives you 2 POTS lines. Careful, the pair from the CO has 100+ VDC on it!
An "overline" is telco terminology for an additional phone number on the same line - as in when a business has 2 lines but only one receptionist. Both numbers ring on the same phone.
