1 members (Scott35), 518 guests, and 16 robots.
#190956 12/13/09 05:53 AM
I forget where I got these from, but found that I had them and thought I'd share. They seem odd to me...
[Linked Image from iamalion.mine.nu]
^ in the socket to the left there are small spikes to pierce the wire
^ a little closer on the end cap...
^ closer still. it reads 75W 125V Levition around the outside, and "Made in USA" surrounding a UL seal.
(move to photo discussion please ^_^)
Made in the USA is refreshing to see! The insulation piercing feature allowed socket placement along either a 2-wire zip cord, or THW strung parallel. IMHO a 'decorative' use item.
i have a few of these, I use a few of these on my Christmas display
-Joe
“then we'll glue em' then screw em'”
-Tom Silva
TOH
We used to call them pin sockets.Used for temp lights years ago.Mainly on fire repair jobs.
Larrypro:
Welcome to ECN forums!
The one in the pic is a candelabra base, but yes they did mfg edison base ones also.
with the small "night light" C7 bulbs?
i would think they would use the regular large sized bulbs
-Joe
-Tom Silva
TOH
I've used them a couple times before. I have a third one, but its broke and I cant find it
I remember years ago, every corner used-car lot had those lights strung around its perimeter, usually on twisted two conductor cabling. They were the standard Edison socket version. You still see a lot of similar "temporary" string lighting using these sockets at Christmas tree stands this time of year.
Eagle used to make a version of these (at least an Edison base version) that was pretty cool. They had a quarter-turn "T" shaped knob that clicked into the closed position and was reusable. The little ones are also available with a metal mounting bracket and were often used in furniture. I have a china hutch that has several of them looped with zip cord in my dining room. It is only a few years old.
---Ed---
I had some of those candelabra base sockets around a makeup mirror in a cabinet I built for my daughter. We put globe bulbs in them for that Hollywood look.
