540
19
Hasn't Mercury Vapor lights ceased to be manufactured?? This was my assumption. Thanks....
Posts: 943 Likes: 2
Go into a big box store & see the junk mercs they sell.But other then that who would want to use them?
I just replaced 10-1000watt MV for a customer of mine. Local supply house wanted $130 a bulb. "Hard to come by because they are becoming obsolete" was his remark. Found them on internet for $20 bucks a piece. Was also told by same supply house R30 75 watt bulbs(for recessed cans) were not going to be available much longer. 65 watt would be highest I could install. Who knows who to believe.
Personally, I wouldn't even think about using dilapidated technology like Mercury Vapour lighting anymore.
There are so many other better options available. The Colour-Rendering of MV lamps and thier relative in-efficency (compared to other light sources) pretty much rules them out in most applications these days.
Even the poor-man's street-lights use High Pressure Sodium or Metal Halide.
Mercury vapors are no longer being sold in stores they will become more $$ as stock declines this is a good time to upsell.
Mercury vapors are no longer being sold in stores they will become more $$ as stock declines this is a good time to upsell. Mercury Vapor lamps are available at the Home Depot in 100 watt mogul base, and 2 versions of 175 watt mogul base at about $15 each, and a 250 watt mogul base at about $18.
I don't believe the fixtures are made anymore, and even the ballasts may be history. Bulbs, as electire notes, are readily available.
Also available at the box stores are special CFL's intended to operate on a mercury-vapor ballast. I've used the bulbs, and they work just fine.
I tried to find a replacement for a 100 watt mercury vapor. I needed an edison base lamp, but the supply house said it was obsolete, so I bought 2 150 watt HPS floods to replace them with. The others gave me problems all the time anyway... HPS seems the way to go anyway when trying to get lamp life hours. (24,000 hrs. lamp life) thanks for the input... Steve
I went looking for a replacement 70W MV ballast for an existing fixture and my lighting vendor said that a Metal Halide ballast will fire a MV lamp just fine, and that the only way he could get an MV ballast was to try and find old stock somewhere. I had to try it because there are another 15 fixtures, and swapping them all out for Metal Halide was not an option.
It actually worked very well, and has continued to work for several months.
Looks like, yes, MV are going the way of vinyl records.
