1 members (Scott35), 536 guests, and 30 robots.
adroga Offline OP
I have a weird question...
Just to preface I am a second year apprentice. I need to replace the gutters and fascia boards on my house, but I only have a 100 amp entrance that is below the roofline.
The feeder wires are supported by a hook that screws into the wood fascia boards that extends below the gutter.
In order to replace the fascia I need to unhook the wire support. Is it wise to leave the wires hanging from the weatherhead for a short period of time? Or possibly use a rope looped behind the weatherhead to support the wires?
Thank you for any advice...
Get in touch with the local utility and tell them what you need to do with the facia board. You may have to install a new attachment and add reinforcing so that the facia board is not the only thing the hook is attached to. I don't know what the utility in your area requires but it is not acceptable here to just use a facia board as the only anchor for a clevis. We require something structural like one of the studs or rafters. it is likely that the utility will use a rope with bunch of half hitches attached to a temporary anchor. cover the service drop with an insulating sleeve etc so it is safe for you to change the facia board. I doubt that even as a partly trained electrician that you are allowed to touch those wires.
