K
KJay Offline OP
Jeez... I guess they would be... $4200.00 for speaker wire?... That is truly insane.
I think I see an opportunity to introduce a line of compact, true "Audio Grade" isolation transformers for ultra clean power for optimum amp performance, complete with battery backup to prevent preset tuner channel memory loss during power outages and two onboard WattGate 381 duplex receptacles.
I could give it an esoteric European sounding name, like "DuhmHaas" and sell them for $6500.00 each. laugh
You just need to start selling oxygen free audio grade romex at these prices. smile http://www.higherfi.com/cables/1
Why not use solid gold romex?
Unfortunately, this Wattgate receptacle isn't offered in a Tamper Resistant model. bash
Dang!! I need 25 of the Wattgate Receptacles for various Audio Equipment around the House, and they have to be Tamper Resistant...
I must have the ultra-awesome Wattgate Receptacles for any Audio equipment - even the AM / FM Clock Radios must use these Receptacles - or risk poor Audio output, possibly major internal ear damage from having to withstand sub-par Audio.
The $145.00 per unit price is a non-issue for pure, clean Audio output from any Audio Equipment!
I also use the $1,000.00 per foot Speaker Cables, connected to Diamond fitted, Platinum Based, Jewel Encrusted 100% Gold (O2 free, of course) Terminals on all Audio Equipment (Clock Radios included).
I am definitely joking around, however I am sure there are many "Wattgate" and similar Customers, whom would refer to the above list as "default" - judging from the fact that the Receptacles are STILL BEING SOLD FOR $140 + !!! eek shocked bash
Just wanted to add humor.
Scott
Scott... You should really bring this up to them... they might even let you test the prototype Leviton with a serial number! whistle
Z
Why do I not have ideas like this!!??
Roll a silkscreen with some blue ink on a $7 spec-grade 20A outlet, then charge an unknowing, over paid sucker $147. Genius!
I only say $7 instead of $2 because this looks like a back-wired screw-down receptacle, which tend to be a tad more pricey.
(BTW, the answer is that I'm not a crook. I prefer to work for a living)
Lostazhell
I contemplated adding the Cut-Sheets to the Submittals package as a bit of humor, but decided against it, as this job has insane specs!
I am submitting cut-sheets on EVERTHING!!! including Tape!!! eek
On the other hand, the Architects are really pushing an expensive design, so they might actually want to use the Wattgate Receptacles, and hire me for performance research!
thumbs
Scott
I am seeing double it must be late laugh
Please pardon the double post!
I deleted the "Redundant Version" wink
Scott
