by HotLine1 - 04/23/24 02:17 PM
0 members (), 231 guests, and 11 robots.
#189378 10/04/09 03:58 PM
V
Can some one explain what is Redundant grounding
The term is used in article 517 (patient care areas) it generally refers to an additional grounding conductor.
They require a properly made up metallic wiring method (your ground) plus an insulated grounding wire (the redundant ground).
Keep in mind the first EGC can be your conduit, then a properly sized insulated EGC inside.
