Wye / Delta Connection Detail Schematics
The following Schematics are relevant to the Wye / Delta Starter Drawings, contained in the above post.
Fig. 1.1: Motor Leads - Pictorial and Common Schematic, with Lead Identifications.
Motor = 3 Phase Squirrel-Cage Rotor type Induction Motor (typical for all drawings)
Fig. 1.2: Connections Details for Single Speed, Single Voltage 6 Lead Motors; External Wye Connections for Starting, External Delta Connections for Run.
Fig. 1.3: Connections Details for Single Speed, Dual Voltage 6 Lead Motors; Wye Connections for "High Voltage",Delta Connections for "Low Voltage".
Fig. 1.4: Connections Details for Single Speed, Dual Voltage 9 Lead Motors; Wye Connections for "High Voltage",Delta Connections for "Low Voltage".
Fig. 1.5: Connections Details for Single Speed, Dual Voltage - Wye Connected 9 Lead Motors: Connections for "High" and "Low" Voltage.
Fig. 1.6: Connections Details for Single Speed, Dual Voltage - Wye Connected 12 Lead Motors: Connections for "High" and "Low" Voltage.
end.
