1 members (ale348),
302
14
well the snow is (almost) gone, and the landscape lights have reappeared after a long winter under the snow.
My Q to this BB, does anyone know of a good hearty variety of low-v landscape lighting ???
Posts: 4,116 Likes: 4
Sparky,
I just put in a Malibu set. They were Aluminum with short leads and 2 piece connectors that puncture the insulation. 20 watts each I think. I don't know how they are long term, but I had no problems with them.
Vista Lighting ( www.vistapro.com) makes an excellent product that's competetively priced, rugged, and there's a good selection. They come as components rather than kits so you can get what you want. (suppose I'll get a free T-shirt from the rep now?)
I know i've asked before, and I apologize, but... How many consider table 300-5, column 5 to require residential low voltage landscape lighting cables to be buried 6"? How many just cover it with mulch per manufacturers instructions? (sorry to jump into your question, sparky)
[This message has been edited by Redsy (edited 06-05-2001).]
Redsy,
What do the instructions say? I don't think it's one of those things that gets enforced a lot. I don't usually get involved in them at all past putting in an outlet for the transformer.
electure, thanks! that is a well defined link, much selection and related info... Redsy, actually that would be the next pertinent Q, on this particular job, the landscping, plants etc are big $$$, the GC would like things durable and low maint. So i have bid it all out in 3/4" pvc with FS boxes at each light location. extending the code loop to 300-5(d) last sentence has this wiring method in question ??? ???
Sparky, Just a thought--- If durability is a concern, I just installed 120 V. Red Dot Site Lites. They use med. base bulbs (A15, R20,etc) and seem very well made. The downside is the 12" burial depth. However, voltage drop was a big concern in my case. (I used 500' of 12-2 UF) Low voltage lighting at those lengths would have been too complicated to try to have uniform brightness. Also, I needed more than 1000 watts total, so I would of needed 2 transformers. Remember that for a given wattage, low voltage draws 10 x the current and therefore a proportionally higher voltage drop. When starting with 12 volts, that doesn't leave a lot of room. If you go 120, remember rocks & roots!!
[This message has been edited by Redsy (edited 06-06-2001).]
http://www.vistapro.com/Trans_CTT%20Series.htm not too bad. good tech support too. Redsy, check out the multi-tap x-former, might do the trick! electure, i vote U get a shirt! [This message has been edited by sparky (edited 07-30-2001).]
