#188484 08/11/09 01:46 PM
mikesh Offline OP
As of August 10, 2009 the 2009 CEC is in effect and contractors may work under either code until October 10, where the 2009 code takes full effect. Contractors may not mix and match codes but can chose 1 or the other during the 2 months.
Thanks
Good thing we have this forum as i would of not known this today
Thanks for the heads up knew it was coming just not when.I hear that we will have less bc amendments.Also has anyone
heard how much time will be required(up grades each year) to
keep our Fsr?
keep our Fsr?
There is some info here.
https://www.electrical-contractor.n...ritish_Columbia_FSR_S_Continu#Post184357
mikesh Offline OP
FSR will require 24 hours every code cycle or about 8 hours of approved training per year. The trick is to determine what training will be recognized. The local BCSA inspectors have regular Teck talks which offer free 2 hour sessions once a month on varying subjects as 1 source for these credits. A 2 day Arc Flash seminar would get you 16 hours in 1 shot.
I can see there could be a challenge for some FSR to get the 24 hours especially once they have waded through 1 or 2 upgrade courses.
