Hi, all. I've been hanging around here for a few months, learning, trying to contribute, and now I have some questions.
One is as follows.
A GFCI receptacle, such as this one
is listed as a 15 amp receptacle, 20 amps feed-through.
I take this to mean that receptacles that are attached to the LOAD side of the GFCI (that is, those receptacles that would be after the GFCI, so if the GFCI trips, those receptacles would also loose power) can be 20 amp receptacles.
If this is the case, why wouldn't the GFCI receptacle be rated at 20 amps, appearing as such
I am having trouble comprehending how a device rated at 15 amps can be on a circuit with a 20 amp breaker. Does that not present a hazard of the receptacle overheating? (Not just in this example of GFCI, but on a circuit that would have a 20 amp breaker, 12 AWG cable, but receptacles rated for 15 amps. Doesn't that allow for overheating of the receptacle and/or that which is powered by it?)
I look forward to your informative answers.
Thanks.
[This message has been edited by ThinkGood (edited 12-15-2002).]
