The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Page 2 of 2 < 1 2
Topic Options
Rate This Topic
#187533 - 06/30/09 02:08 AM Re: Service Change: I got lucky! [Re: gfretwell]
NORCAL Offline
I live in a house built in 1943, original panels were 2- SQ D 2-pole Multibreaker load centers nippled together over the kitchen counter providing the generous sum of 4 circuits in the entire house, the last of which was removed in the early 1980's, The SQ D, Cutler-Hammer XO replaced the Multibreakers which in turn was obsolete by about 1960, replaced by SQ D QO & Cutler-Hammer type CH series.
Some raintite enclosures were avail in the 50's but IMO due to the lack of inspections or other factors a lot of "indoor" equipment was used outdoors because no one made them use the correct gear or build a dog house around it.
Top
#187540 - 06/30/09 03:26 PM Re: Service Change: I got lucky! [Re: NORCAL]
HotLine1 Online   content
Loc: Brick, NJ USA
The 'doghouse' was a popular way of 'enclosing' gear around here a while back. Pc. of plywood & a few shingles, wow...it's protected.
_________________________
Top
#187551 - 07/01/09 08:35 AM Re: Service Change: I got lucky! [Re: HotLine1]
WESTUPLACE Offline
Loc: Kingwood, TX USA
Here in TX the 2 most common ways of enclosing the panels were to mount the meter and panel under the porch roof near the ceiling, sometimes the meter would be mounted outside with the panel under the roof. (common with screen porches) The other common mount was the meter was surface mounted on the side of the house with the panel mounted below, bolted to the back side of the inside wall.(shiplap) A wood or plywood door covered access to the panel. If you opened the door, you could see the inside of the wall cavity making fishing wires easy. Many pre war houses had a 2 ckt safety switch with 2 30a ckts serving 2 14 ga K&T common neutral ckts.
Robert
Top
#187554 - 07/01/09 11:29 AM Re: Service Change: I got lucky! [Re: WESTUPLACE]
EV607797 Offline
Loc: Springfield, VA, USA
Yeah, that's how a lot of older houses in NC are done too. A 60 amp panel with a main pullout and a range pullout, then four plug fuses below. All right out on the porch.
---Ed---
Top
#187606 - 07/03/09 12:39 PM Re: Service Change: I got lucky! [Re: EV607797]
Texas_Ranger Offline
Loc: Vienna, Austria
Reminds me of the old tiny farm houses in my area of Austria. All L-shaped and built next to each other with the short side facing the street. Roof spans the whole width (often no more than one room plus hallway) and on one side or down the center there's a set of huge carriage doors leading to a covered drive to the backyard (no doors on the back). When these places were wired, some of the tinier only had one circuit (10 amps I guess, maybe even 6) and the fuses and meters (fused neutrals) out in the drive.
Top
#187873 - 07/12/09 11:41 PM Re: Service Change: I got lucky! [Re: Texas_Ranger]
Theelectrikid Offline
Loc: Lower Bucks County PA
The older 1952-56 Levittown, PA houses all had fuse boxes originally, despite the ads advertising breakers. The 1957 models came with breakers as far as I know, apparently Levitt couldn't get a three-pull-out panel for the added central A/C for cheap enough!
Almost every house that still has the original service around here is a ticking time bomb, with all of the added air conditioners, appliances, not to mention additions!
John, that install looks good, nice to see it work out, I'd probably do something similar. Oh, and is that asbestos I spy behind that strut? wink
Ian A.
Edited by Theelectrikid (07/12/09 11:44 PM)
"Hey no wonder the water don't woik, the pipe is plugged up with wires."
Top
Page 2 of 2 < 1 2
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
