The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Live Chat
Join in a Live Electrical Chat!
>> Enter/Register
  Sorry, your browser is not Java enabled, please visit our java support pages in Chatroom
Looking for a unique adjustment nut
by sparkyinak
02/09/12 02:16 AM
A taper or B taper, which is it?
by JoeTestingEngr
02/09/12 12:39 AM
GE low-voltage remote control relay system
by Albert
02/08/12 10:26 PM
Electrical systems in mobile structures.
by gfretwell
02/08/12 09:21 PM
Conduit Bending Apps for iPhone -Master Bender
by KJay
02/08/12 08:31 PM
A What's right here??
Shout Box
Top Posters (30 Days)
gfretwell 72
HotLine1 66
KJay 34
sparky 28
renosteinke 26
Classified Ads:
Electrical-Classifieds.com
Who's Online
0 registered (), 103 Guests and 2 Spiders online.
Topic Options
Rate This Topic
#185110 - 03/03/09 09:06 AM Electrical problem
willijimon Offline
Loc: San Diego
An electrical outlet is hot to the touch but nothing is plugged into it
Top
#185111 - 03/03/09 09:52 AM Re: Electrical problem [Re: willijimon]
sabrown Offline
Loc: Ogden, Utah, USA
A receptacle that is hot with nothing plugged in is a sign of wiring failure. This may cause a fire at any time. PLEASE turn off the circuit breaker to this receptacle immediately and call a qualified electrician to correct the problem. Do not do this yourself, even if you have some qualifications, there are major problems you will likely miss.
Top
#185120 - 03/03/09 01:08 PM Re: Electrical problem [Re: sabrown]
gfretwell Offline
Loc: Estero,Fl,usa
99.9% of the time this is just going to be a loose connection at the receptacle. I bet you are also =having problems down stream (flickering lights etc). An AM radio is probably painful to listen to.
Mr Brown is right. Get this checked out before you have worse problems.
Do you have aluminum wire?
_________________________
Top
#185123 - 03/03/09 03:54 PM Re: Electrical problem [Re: gfretwell]
HotLine1 Offline
Loc: Brick, NJ USA
Willijmon:
As your profile does not indicate you are in the electrical trade....
Please contact a licensed professional in you area to check your 'hot' receptacle promptly.
I am locking this thread, as providing 'advice' to DIY people is non-approved.
Top
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
