#182456 11/27/08 01:54 PM
Redsy Offline OP
I usually use 12/2 NM when feeding(Seagull Ambience)undercabinet lights (up to 300-watt transformer).
However the terminal-type connection block is sometimes tedious with #12.
I have seen #14 used, and if the load is divided appropriately such that no particular section can exceed 150 watts, I assume that this would be fine.
Any thoughts?
Thanks,
John (Redsy)
Hi Redsy,
I use Juno Trak 12 instead of the Ambience. The track is more but the labor is way less. 12-2 Rx to each local tie into end of trak connector screw track to cabinet snap in heads and you are done. No special wire or cutting cover to fit the heads can be move or changed. I have tried to add to older ambience and when that cable gets hard the heads will not pierce the cable. That said I would still use the 12 wire for your application.
Ob
Redsy Offline OP
Thanks, Obsaleet.
I will look up Juno today.
Redsy
