Electricians revenge
0 members (), 161 guests, and 10 robots.
#178489 06/01/08 05:38 PM
A client has a large warehouse (15k+ sq.ft.) and has had problems leaving the door open late at night and things "walk" away.
He wants to locate a "buzzer" outside that will go to some sort of horn inside that will get get the crew's attention that someone is at the door.
Any suggestions on manufactures for this product? I'm not even sure exactly what I'm asking for even though I've seen them a hundred times.
I do want to make sure this is industrial/commercial grade since the buzzer may endure some abuse.
Thanks,
Byron
The mechanics of making such a thing is pretty easy. Probably the easiest solution is to ask an alarm contractor to install it.
While he's at it, perhaps some cameras are called for. I suspect the losses are not purely by chance.
How about a viking electronics doorbox wired to a spare line on the phone system....
twh Offline
