by NORCAL - 03/19/24 05:11 PM
1 members (gfretwell), 32 guests, and 14 robots.
#181555 10/15/08 11:43 PM
Merlin Offline OP
I have a 0-75 Ammeter that I need to install. This meter is a direct connection meter that does not require a current transformer. I am not sure of the proper connection this way. I have always previously insatlled the ones with the CT. Can someone give me the right connection procedures. I want to make darn sure that i hook it up right. Thanks, Merlin
Does it have lugs big enough for 4ga wire?
Merlin Offline OP
If i remember right, it has 1/4-20 studs.
JBD Offline
A direct connected meter is installed in series with the load.
JBD #181562 10/16/08 11:22 AM
-----0-0------- Line 1 --------------load--]
shunt ^
--------------- Neutral or Line 2 ----load-]
Directly in series with the load. Take one leg of the load and connect it to the meter. Take the other supply leg and connect it to the meter.
Motor - Meter - Line. Example only
Merlin Offline OP
Ok. I thought that was the case but didn't want to let the smoke out not being sure.
Also, bear in mind that the supply will need to be de-energised while this meter is installed, trying to do a job like this with the power still connected is just silly.
Funny, just a little while ago I was thinking about those old ammeters we used to have on the dashboards of our cars.
