221
11
I've been looking on line for the evolution of the light bulb and a catalog of the different types and wondered if anyone happened to know of a handy source. I've found out a few things, such as the number after the letter classification tells you the highest width in eighths, such as a T-8 is equal to 1", an A-19 is equal to 2 3/8's inches, but I thought there might be an all inclusive sight around.
Posts: 9,928 Likes: 34
I had pretty good luck at Bulbman.com We got attached to the 15w sign bulbs with the S14 envelope. They really look good in any antique type accent light. These seem to be the only guys who stock them.
Posts: 7,381 Likes: 7
Gunther: The Grainger catalog also has a lot of bulb 'info'
Also, Philips Lighting website may be helpful o you.
As far as the 'history' part...google 'Thomas Edison' for starters.
I do know the Sylvian do have good info on it as well.
Merci,Marc
The letter indicates the type of bulb, the number is diamater in 1/8" increments. Additional letters may indicate type of filament, frosting, base type, distance from base to filament center, etc.
A few types off the top of my head:
A - standard "light bulb" style G - Globe PS - Pear shaped T - Tubular PAR - Parabolic Aluminized Reflector R - Reflector MR - Mirrored Reflector
Base types:
Medium Screw (regular household light bulbs) Mogul Screw Candelabra Mini-Candelabra Medium Pre-focus Mogul Pre-focus Medium 2-pin Medium bi-post Mogul Bi-post Recessed Single Contact Miniature Round Pin (i think - found on some MR-16 type projector lamps) Miniature Flat pin (i think - found on some MR-16 type projector lamps)
Most stage/studio type lamps also have a 3 character ANSI code.
EGG - 750w clear tungsten-halogen T6 coil filament Medium Pre-focus 2000 hour color temp 3050 degrees K. FEL - 1000w clear tungsten-halogen T6 coil filament medium 2-pin 300 hour 3200K EHG - 750w clear T-H T6 coil filament med 2-pin 2000 hr 3050K EHF - 750w clear T-H T6 coil filament med 2-pin 300 hr 3200K FFS - 1000w wide flood TH PAR64 300 hr 3200K FFN - 1000w narrow spot TH PAR64 300 hr 3200K BTN - 750w clear T-H T6 planar filament medium pre-focus 2000 hr 3050K
