Electricians revenge
1 members (Scott35), 184 guests, and 13 robots.
#178862 06/13/08 10:47 PM
bot540 Offline OP
I am looking to purchase a label maker soon. What's a good one for labeling panels, wires, devices, and whatever I need to label.
Jesus may have been a capenter,but God was an electrician.Genesis1:3
bot540 #178863 06/13/08 11:58 PM
the best one that i have seen is a brady labelmaker. The printer itself can connect to a computer for all sorts of fancy label making, but in terms of suitability for electricians it is amazing. It prints wire numbers on inserts for sleeves and will serialize/increment them, on heat shrink tubes, and magnetic pushbutton labels are available.
On the spools for the material to be printed on, it also featurs an id chip of sorts that contains the details of how much printable room there is, etc which makes it easy to change spools without worrying about settings.
it came in a heavyduty case, with a mains charger/adaptor and is also battery powered.
http://www.bradyid.com/tls2200
bindi #178870 06/14/08 03:37 AM
For most of my work in labelling panels, switches (where required) and outlets, I use a Brother Label-maker, it is ruggedly built, rain-proof and is quite easy on label cartridges, provided you don't try and write a novel on each label.
Trumpy #178878 06/14/08 10:34 AM
I think Mike and I have the same simple $30 label maker. It's perfectly adequate for marking panels. You'll uses scissors pretty often to trim the labels, and the label adhesive usually works pretty good.
Where it falls short is for marking wires, etc. The adhesive just isn't up to the demands 'outside the panel.'
The big advantages? Label tape is cheap, and can be found in any office supply house. While the Brady and Panduit printers have more functions, and better tapes ... so far I haven't felt the improvements justified spending the 5X higher price.
renosteinke #178879 06/14/08 12:58 PM
I have Casio, Brothers & a Rhino (Dyno) Casio easy to use, labels ok for panels but not for wire or most other surfaces. They will fall off after short time. Same for the Brother but somewhat harder to use. I got the Rhino free with the purchase of 10 labels. Works great. The cloth labels will stick and stay on most any clean surface including wire. They make heat shrink labels and the menu has electrical, telecom and data symbols. Labels can be bought every ware. I like the Brady also. The Rhino is a good lower cost alternative to the Brady.
WESTUPLACE #178887 06/14/08 09:30 PM
For me:
* Brother P-Touch for:
Equipment Identification Labeling (Panelboards, Outlets, etc.);
* Brady Labeler for:
Wires, Cables, and Terminals.
Scott35
bot540 #178908 06/15/08 07:35 PM
The Brady that bindi called out is the one
I would go with but it is not cheap. It does a thousand different things from wire numbers to huge banner type signs and bar codes even. You can choose from many different types of labels and colors.
Scott35 #178915 06/15/08 10:09 PM
U
Originally Posted by Scott35
For me:
Same here.
I haven't gotten into much wire labelling yet, but I like Panduit's sheet of plastic labels you can wrap onto wires and cables. You can hand-write or run them through your printer. I've used it in the past and like them.
u2slow #178918 06/15/08 10:19 PM
I use the brady ID pal it was only a $100. and the tapes last awhile. They do a nice job with wire and panels The max width tape is limited thou.
http://www.bradyid.com/bradyid/scv/...lers-and-Supplies/Handheld-Labelers.html
ob
bot540 #178921 06/15/08 10:59 PM
K
I'd say if you have the need and the coin for the Brady, then that’s great.
I use a Dymo LP300, which prints 1/4”, 1/2” and 3/4” wide labels. The 1/4”are great for data ports and labeling switch and receptacle plates.
The 1/2” is what I use most for labeling J-box covers, panels, disconnects and just general labeling. The tape cartridges aren’t too expensive and come in lots of colors, but I primarily use yellow, white, silver/chrome and clear.
For labeling wires and terminal strips, I just use the pads of Ideal cloth backed sticky labels.
I also still have one of the old Dymo/Esselte 1570 embosser type labelers. It still seems to be the most durable for long term labeling under some conditions.
