Live Chat
Join in a Live Electrical Chat!
Electrical Chat
Schedule:  9pm EST
Wed - Business Chat
Friday - General Chat
>> Login
  Sorry, your browser is not Java enabled, please visit our java support pages
in Chatroom
Shout Box
Frank Adam 1918 Newspaper Clipping
Frank Adam Fan Outlet ad
NH Ice storm damage - Loudon NH
Outlets in the park v2.0
Who's Online
3 registered (Alan Belson, Hutch, Jim M), 17 Guests and 5 Spiders online.
Page 1 of 5 1 2 3 4 5 >
Topic Options
Rate This Topic
#177693 - 05/09/08 08:16 PM inexpensive coax tester
jkraft Offline
Can anyone direct me to an inexpensive coax/video tester. I'm looking to cut into an existing coax in an attic with a splitter and don't know which end will be the feed. Hate to carry a TV up there with me.
TIA,
Joe
Top
Featured Tools
#177694 - 05/10/08 12:00 AM Re: inexpensive coax tester [Re: jkraft]
sparkyinak Offline
Loc: Alaska
can you ring it out with a ohm meter?
_________________________
"Good judgment comes from experience. Experience comes from bad judgment."
Top
#177705 - 05/10/08 11:35 AM Re: inexpensive coax tester [Re: sparkyinak]
ameterguy Online   content
Loc: Mass
If possible open up the coax at a connector before the attic & clip the shield and center connector together. Once you are in the attic, you can find determine which end of the cut cable of shorted with a ohm meter.
Top
#177720 - 05/10/08 06:26 PM Re: inexpensive coax tester [Re: ameterguy]
EV607797 Offline
Loc: Lorton, VA, USA
Home Depot sells a relatively inexpensive tone/trace unit for about $50.00 that is made by Ideal. It's not very sophisticated, but is generally intended for just the kind of simple stuff you are looking to do.
---Ed---
Top
#177722 - 05/10/08 06:40 PM Re: inexpensive coax tester [Re: EV607797]
Trumpy Moderator Online   content
Loc: South Island, New Zealand
A 1.5V penlite cell and an LED would do the same thing.
Complaints?,take a number.
Mike.
Top
#177772 - 05/11/08 07:27 PM Re: inexpensive coax tester [Re: jkraft]
cableguy619 Offline
Loc: Iowa
As a cable technician, I recommend/request the following: DO NOT PUT THE SPLITTER IN THE ATTIC!!!!!!!!!! Run the new line back to the existing splitter, and either use an unused port on that splitter, or add another splitter to the existing one.
Top
#177777 - 05/11/08 08:46 PM Re: inexpensive coax tester [Re: cableguy619]
Theelectrikid Offline
Loc: Lower Bucks County PA
With my dad being a cable guy, I gotta agree. Run it to the source, don't tap off.
Ian A.
"Hey no wonder the water don't woik, the pipe is plugged up with wires."
Top
#177781 - 05/12/08 01:06 AM Re: inexpensive coax tester [Re: Theelectrikid]
dougwells Moderator Online   sleepy
apprentice moderator
Loc: kamloops BC Canada
these are like 15.00
doug wells
Top
#177790 - 05/12/08 05:06 AM Re: inexpensive coax tester [Re: dougwells]
SteveFehr Offline
Loc: Chesapeake, VA
I did an analysis of the CATV system in my home when I first got HDTV, and was astonished to discover I was splitting my signal down to about 2% of the original signal at the box. All the splits really add up...
5-way splitter at the drop- 4 ea to 4 TVs in the old house, 5th to another 4-way splitter in the addition. And then that goes to a 2-way splitter to feed the DVR and TV inputs. The DVR then has an internal 2-way splitter for the dual tuners.
20% x 25% x 50% x 50% = 1.25% per tuner in the DVR, both of which had crappy signals and a horrible picture that would constantly break up on several channels and never work at all on a few others. What it DID have, though, was an excellent signal meter! I added a 15dB amp, which increased signal strength, but didn't solve the problem, which was never signal strength (despite the losses), but signal-to-noise ratio- and the noise remained. I troubleshot all the connections and other lines, but the difference was negligible. (Even when disconnected from cable, I was getting a clear picture of several channels on my one TV- there was just that much EMI bouncing around.) The additional grounding point the amp offered is what finally fixed my TV- Grounded the amp, and BAM, every analog TV in the house cleared up considerably, and errors dropped to 0 at the DVR. Problem solved! My analog TV pictures are still quite lousy, though. I blame my neighbors, gotta be their fault, probably using a coat hanger instead of RG6 or something.
So... ah... don't mind the haters, just use a splitter in the attic ;\)
Top
#177813 - 05/12/08 08:18 PM Re: inexpensive coax tester [Re: dougwells]
jkraft Offline
So what is it and where do I get one?
Top
2008 NEC & Related Books, Tabs, CD-ROMs & Exam Prep Study Guides
Tools for Electricians
 * * * * * * * * Licensing Info and Lookup
Licensing Info
& Lookup
VFD BURNING OUT MOTOR BEARING
by GETELECTRIC
Today at 03:02 PM
Sizeing a whole house generator
by EV607797
Today at 02:18 PM
Ballast voltage re-configure?
by gfretwell
Today at 02:04 PM
Theater Electric
by ghost307
Today at 01:46 PM
Required Sign Circuits
by pdh
Today at 12:26 PM
Top Posters (30 Days)
renosteinke 48
Trumpy 48
gfretwell 46
HotLine1 40
pdh 31
January
Su M Tu W Th F Sa
1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
