Live Chat
Join in a Live Electrical Chat!
Electrical Chat
Schedule:  9pm EST
Wed - Business Chat
Friday - General Chat
>> Login
  Sorry, your browser is not Java enabled, please visit our java support pages
in Chatroom
Shout Box
Frank Adam 1918 Newspaper Clipping
Frank Adam Fan Outlet ad
NH Ice storm damage - Loudon NH
Outlets in the park v2.0
Who's Online
8 registered (A-Line, bwise121, dougwells, HotLine1, renosteinke, Retired_Helper), 28 Guests and 9 Spiders online.
Topic Options
Rate This Topic
#177577 - 05/07/08 07:56 PM G.E. 60's Era Low Voltage House System
highground Offline
Loc: Chama, NM
Hello all,
I know I have seen this question come up from time to time.
I came up against a General Electric low voltage light switching system with several defective relays. Are there parts still available? The relays were red and were in two rows on either side of the panel. I didn't have time to poke around much, are they AC or DC? Voltage? What do you guys do, hunt down the replacements or replace with an appropriate ice cube or such? Are there switches and cover plates available from anybody?
Thanks
Top
Featured Tools
#177579 - 05/07/08 09:03 PM Re: G.E. 60's Era Low Voltage House System [Re: highground]
EV607797 Offline
Loc: Lorton, VA, USA
Here's a link to a comparable product line that might help:
http://www.touchplate.com/cutsheets/cps8-48_manual.pdf
Also, if you search "touch plate" on this forum, you'll find a few threads about low voltage switching over the past year or so.
I'm pretty sure that the Touch Plate system is compatible with GE's version for the most part. These systems operate on 24-30 volts DC to keep the relays quiet.
_________________________
---Ed---
Top
#177580 - 05/07/08 09:09 PM Re: G.E. 60's Era Low Voltage House System [Re: highground]
twh Offline
Loc: Regina, Sask.
If they look like this:
http://www.dale-electric.com/detail?itemnumber=RR9
I get them from the local GE dealer. They are available in AC and I've seen DC.
Top
#177607 - 05/08/08 09:14 AM Re: G.E. 60's Era Low Voltage House System [Re: twh]
SolarPowered Offline
Loc: Palo Alto, CA, USA
Those sound like standard GE RR7 and RR9 relays. They are still available, and used in new lighting control systems. (Although, these days it's typically a computer that turns them on and off.)
Top
#177670 - 05/09/08 10:51 AM Re: G.E. 60's Era Low Voltage House System [Re: SolarPowered]
Albert Offline
Loc: Falls Church, VA
Just a historical note which might be of interest: I was browsing through a 1949 issue of Electrical World, and saw new-product announcements for manual and motor-driven selector switches for the GE system. I didn't realize the product line was that old.
Top
#177673 - 05/09/08 12:06 PM Re: G.E. 60's Era Low Voltage House System [Re: EV607797]
electure Moderator Offline
Loc: Fullerton, CA USA
I don't believe that the systems are compatible.
The touch plate requires a transverter that operates at 28-30 Volts DC. It's a mechanically held ratcheting design, (push the same contact for on/off) that uses a 2 wire control.
GE's design is a 24-29 Volt AC,30-38 Volt DC mechanically held 3 wire control with both "on" and "off" coils (requiring separate on/off contacts)
Top
#177675 - 05/09/08 12:46 PM Re: G.E. 60's Era Low Voltage House System [Re: electure]
EV607797 Offline
I'm sure that you are correct. It's been over 25 years since I worked with those much. My boss was the crafty one who managed to find ways for us to service these systems. He was much smarter than I was at that time.
---Ed---
Top
#177695 - 05/10/08 04:22 AM Re: G.E. 60's Era Low Voltage House System [Re: EV607797]
jdo1942 Offline
Loc: st. louis, mo. usa
Although the relays are available, be aware that there two types, a three wire and a two wire. The two wire units are not available, if you have that type you use an "ice cube" relay and a standard switch.
Also know that the switches are not available in the their original form, P & S does make a replacement but does not look the same.
Joe Ogle
Top
2008 NEC & Related Books, Tabs, CD-ROMs & Exam Prep Study Guides
Tools for Electricians
 * * * * * * * * Licensing Info and Lookup
Licensing Info
& Lookup
California referal fee legal question
by HotLine1
01/07/09 08:23 PM
Three way switches
by Samurai
01/07/09 08:19 PM
Required Sign Circuits
by HotLine1
01/07/09 08:15 PM
Theater Electric
by HotLine1
01/07/09 08:02 PM
800 amp transfer switch
by HotLine1
01/07/09 07:39 PM
Top Posters (30 Days)
renosteinke 49
Trumpy 48
gfretwell 46
HotLine1 42
pdh 31
January
Su M Tu W Th F Sa
1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
