Ideal square leather tote:
Crimper / Stripper / screw cutter Burndy HYTool
stripper or romex stripper not in belt
insulated, holding screwdrivers:
3mm x 5in, 4mm x 5in & 5mm x 6in
#1 x 5in & #2 x 7in Phillips
Screwdriver and conduit reamer Klein 85188
Screwdriver 1/8 x 2 craftsman 41421H
Screwdriver 3/16 x 2 Wiremold Plugmold
Screwdriver 1/4 x 4 & wirenut wrench Ideal 30-331
insulated Screwdriver #1 Phillips & 3/16 x 4-1/2 GB SCE-260
insulated Phillips starter / magnet Stanley
Neon tester
Outlet / GFI tester GB GFI-501
DVM w/non-contact thermo Craftsman 81079
Test lead set for above:
standard probes
alligator
mini-hook
banana / prick
thermocouple
triangular file
wood screw starter hole Irwin 900
cheap ballpoint pen
Mechanical carpenter's pencil & spare lead
10" magnetic level
crimper, Ideal crimpmaster with following dies:
RJ-45 Ideal 30-559
Coax Ideal 30-582
RJ-11 Ideal 30-556
Slip-joint pliers 10" Proto 280
cable cutting pliers 9-1/2" Klein 63-050
10" end adjustable wrench (Klein?
taped handle)
Fuse puller Holub 64
power screwdriver Black & Decker VP750
For above:
Magnetic bit holder, shroud
2 PH1, 2 PH2, Robertson, Straight #5, #5-6, #6-8, #8 & #10-12 bits
spare battery
Scissors, telecom Fiskars 9485
Tape, yel, grn, blu, red
Bits and dies in small tackle boxlette
Test leads in roll pack
