519
18
From amurrayI saw this image on CNN . com and was curious what the real story could be (assuming the picture is real). It would appear someone took the NEC requirement for a receptacle in a bathroom to an extreme
Never, ever under estimate the "creativity" of human beings.
The meter is on a separate structure from the porta-potty. I don't know, but maybe this is just the storage area for United Site Services? A search on that phone number turned up this site: http://www.unitedsiteservices.com/markets/northern-california.htmlIn addition to porta-potties, they also provide temporary power, including hookups to the local POCO ... which would require meters, of course!
Well, that would be one way to save space on the jobsite, Consolidate your temp service and facilities in one unit! Hey, even put a ventilation fan in there
Cliff
The meter is on a separate structure from the porta-potty.... Gees, just take our fun away ...In addition to porta-potties, they also provide temporary power, including hookups to the local POCO ... which would require meters, of course! That is an interestion business venture. "Bob's Electric and Porta Potty Service"
OK, just to play devils' advocate .... many of those porta-potties have sinks in them. Why should the receptacle requirement NOT apply? After all, many of them sit in the same place for years on end.....
Because when the wind blows the thing over, the blue stuff will ruin the GFCI
After all, many of them sit in the same place for years on end..... Are you talking about the porta jon or the ones who usually uses them all the time?
I am assuming that out of the frame there is a huge concrete block anchoring that blue steel thing in place... or.. maybe not?
