#174990 02/19/08 08:18 AM
leland Offline OP
[Linked Image from electricalphotos.com]
I over heard the sider say "no extra charge for the use of the van"
Additionaly, The guy on the (ice coverd) roof is tied off.With a 1/2" rope from the rafter to his waist.
All in 1 shot.
(ps: bear with me, still learning the photo site and use)
leland,
On the photo site if you go down below your picture to where is says 'linked thumbnail' and click on the little thing to the right of the box where you copied the url it will drop down and offer more links to a 'medium' sized image which will give you a bigger picture to post.
Here are the two other selections, one has a link back to the page with the picture on it.
'Linked Medium'
'Medium Image'
I used a redneck bucket truck like that before, but I used a fiberglass ladder though. Safety first you know.
leland Offline OP
Thank you Bill.
As far as safety, There is a sheet of 1/2" plywood on the roof of the van.
Can never be too safe ya know!
1/2" That's all?
I'd use 5/8" wink
Ian A.
Remember, no AC plywood! Inner layers can have voids. Stick with underlayment-certified. sick
Everybody does know we're joking, right? grin
I don't understand why they needed a ladder at all- that style siding jack includes an integrated lift. Are they just too lazy to drop it back to ground level for lunch?
We're laughing at the ladder set on the van roof ... which actually might not be such a bad base. Far worse is the use of another ladder as a scaffold plank.
I've witnessed industry standard ladder tests, and the load a ladder is subjected to in the horizontal position is nowhere near as large as the load used when the ladder is in the 'set up' position. Ladders just are not designed to be used as planks!
I believe they're just using that ladder as a safety rail/work platform. If you look closely, there's a typical solid siding platform to stand on just below it, with that ladder mounted about waist height.
Though, the way they placed the (van) ladder makes you wonder just how they get from the ladder to the work platform! I hope they aren't crawling over that ladder- it's one thing to lay sheets of siding on it, but there's no way it can safely support a man's weight.
That's easy. They have not gotten that high yet but when they are ready, they will climb and reach down and snatch the six footer leaned against the side door. They will just put it on the plalk and go up to the next level. Either that or Aussie repel from the peak. That would be my preference.
