The Electrical Contractor Network
ECN Electrical Forum
Discussion Forums for Electricians, Inspectors and Related Professionals
Books, Tools and Test Equipment for Electrical and Construction Trades
Page 1 of 3 1 2 3 >
Topic Options
Rate This Topic
#174795 - 02/13/08 09:53 PM Homemade Lighting Control System
Webmaster Offline
Loc: NY, USA
Quote:
I was sent to work on a lighting control system on a multi million dollar house that overlooks the San Francisco bay. The last thing that I ever expected to open the door and find was this little home built beauty. It seems like it would have been a lot less trouble for the electrician to just buy a real lighting panel.
The guy that built this thing and wired the house has since disappeared and can't be reached.
Scameron81
Top
#174803 - 02/14/08 04:33 AM Re: Homemade Lighting Control System [Re: Webmaster]
LarryC Offline
Loc: Winchester, NH, US
Are te silver colored canisters at the bottom mercury wetted relays?
Larry C
Top
#174807 - 02/14/08 06:18 AM Re: Homemade Lighting Control System [Re: LarryC]
NJwirenut Offline
Loc: Bergen County, NJ
The cans at the bottom appear to be standard low voltage lighting control relays. Those are usually dual coil latching relays--one coil is pulsed on to turn the lights on, and the other is pulsed to turn them off.
The enclosure may be homebrew (not even sure about that), but that PC board sure isn't. There should be a manufacturer's name or model number on it somewhere, and a Google search might find info on it.
The input and output wiring, while messy, should be easy enough to trace out once you have an idea how the PC board and the relays function.
Edited by NJwirenut (02/14/08 06:20 AM)
Top
#174826 - 02/14/08 05:21 PM Re: Homemade Lighting Control System [Re: NJwirenut]
HotLine1 Online   content
Loc: Brick, NJ USA
NJ:
Looks like the 'old' GE LV lighting controls, and yes, the box may be 'factory', although the circuit board is NOT something I have come across.
Livingston/So Orange older homes were big on the GE LV controls....note the word 'older'. Board may be some interface with a computer type control?
Yes...sloppy, but can be made neat.
_________________________
Top
#174830 - 02/14/08 09:13 PM Re: Homemade Lighting Control System [Re: HotLine1]
NJwirenut Offline
The board definitely appears to be some type of interface between "something" and the relays. Doesn't appear to have much in the way of "smarts" on it (I don't see anything resembling a CPU).
Top
#174833 - 02/15/08 12:32 AM Re: Homemade Lighting Control System [Re: NJwirenut]
Rewired Offline
Loc: Hamilton, Ontario, Canada
Well they tried, at least there is a rubber grommet ( thats falling out) on the bottom left that most of the wires are passing through instad of a sharp edged hole... but man, what a mess! that wooden " backplate" has to go too LOL
Top
#174834 - 02/15/08 05:15 AM Re: Homemade Lighting Control System [Re: Rewired]
electure Offline
Loc: Fullerton, CA USA
You want a cutsheet ?
It IS a factory made lighting control.
http://www.touchplate.com/cutsheets/cps8-48_manual.pdf
Top
#174837 - 02/15/08 06:29 AM Re: Homemade Lighting Control System [Re: Rewired]
NJwirenut Offline
Why?
Wood backplates are sometimes seen in low voltage/telecom enclosures. They certainly make mounting additional components in the field easy (no drilling/tapping, and no worries about wayward chips shorting anything out).
Hoffman provides them in some of their datacom cabinets. I have installed a bunch of these:
http://www.hoffmanonline.com/product_cat...378&itemID=3593
Top
#174844 - 02/15/08 11:56 AM Re: Homemade Lighting Control System [Re: NJwirenut]
Trumpy Offline
Loc: SI,New Zealand
Guy certainly made sure he had plenty of wire nuts before he fitted-off that panel.
Look at them all!.
Let's face it, these days if you're not young, you're old - Red Green grin
Top
#174849 - 02/15/08 12:39 PM Re: Homemade Lighting Control System [Re: Trumpy]
trollog Offline
Loc: San Diego California USA
My first thought was "I've seen worse"
I'de give that a 5 out of 10, ten being the worst.
Top
Page 1 of 3 1 2 3 >
ECN Electrical Forums - sponsored by Electrical Contractor Network - Electrical and Code Related Discussion for Electrical Contractors, Electricians, Inspectors, Instructors, Engineers and other related Professionals
