#174698 02/12/08 12:04 AM
Hi,
I saw this thing a while ago at a show. It was used to control 4 stage lights from the sound board. Quite scary.
I thought you guys might get a kick out of it.
Cheers,
William B.
[Linked Image from electrical-photos.com]
Admin #174700 02/12/08 12:23 AM
Use #4001 for duct tape...
Admin #174703 02/12/08 12:56 AM
At least the delicate connections and sensitive switches won't get abused during transport. Not to mention it makes a very nice finger warmer, for the poor sound man during those cold club shows.
Larry C
K
KJ Offline
wow, talk about low budget productions
KJ #174705 02/12/08 05:46 AM
Reminds me of a self-employed (and trained) DJ... he had his own light control box, basically a wooden box with a pile of regular light switches and Schuko receptacles. At least they had covers.
the feed however... he had a spare, unswitched receptacle on the side and used it to backfeed the entire box using a cord with two plugs! (and yes, I mean two male cord caps...)
I just found it on my photobucket account.
The plug on the left hand side runs the entire thing.
[Linked Image from i17.photobucket.com]
KJ #174709 02/12/08 08:26 AM
Have you ever priced those Pelican boxes? Not exactly "low budget" stuff.
Why would put an abomination like THAT inside one is beyond me, though...
Aw, now, you guys are too rough :<) . Notice how he color-coordinated the switches and receptacles!
It is an unusual combination of "values" - a very nice (pricey) case and a couple of dollars worth of parts thrown together.
Ranger; It's interesting you mentioned the "double male" power cord. A band around here had a similar setup like this, playing in an ancient dance hall one night. A "roadie" tripped on the power cord, unplugged it from the controller, the cord fell onto an aluminum case sitting on the floor beneath. Caused a short circuit that knocked out every light in the joint and started a small fire in the main fuse box. Delightful evening on the fire engine that night...
N.J.; Those cases are wonderful. They're just right for carrying around wireless microphones.
I once came across a disco light box (one of those three-channel bass/mid/treble flashing jobs) which had been built with 3.5mm mono jack sockets for the light outputs. Only the tip of each plug was used as the current-carrying conductor, so there were separate line and neutral jacks for each of the three channels. All at 240V here, of course.
Yeouch! Now that's a bad one!
That case would look at home at a few dive bars around here... (Except the case part, too pricey... maybe a milk crate from behind Circle K...)
