by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
1 members (Scott35), 376 guests, and 11 robots.
Greg,
I almost forgot, if there is a light on the bottom of the deep end of a pool, How much wire can be stuffed inside of a wet niche? Enough to reach the edge of the pool? Or do you have to pull the wire all the way out of the pipe in order to replace the light.
F
Originally Posted by harold endean
Greg,
if only down about 24" below water line useally plenty cable in there but here a trick go to bottom i really doubit unless they make super deep niche box for it other wise you will have to disconnet that {beep} wire and tied to fishtape or something so you can pull it back.
Merci, Marc
