We figured out the problem today. The satelite finder meter was not calibrated properly, and therefore the dish never was aimed properly. We re positioned the dish. And it worked perfectly. So long story short is I could have saved alot of headaches, and checking, and double checking of connections if I checked the claibrations of the meter first. dohhh. Now I know.
I have a better respect for the installers now. Except for the hacks who run the coax along the side of buildings and drill in where they think the tv, or computer will go. That is a terrible way to install anything.I've seen first hand one of the dish networks' contractors drill through the wall in my apartment, through the electric baseboard heat. and the kicker is he ran the coax right through that hole in the heater. That was a pretty hack job, especially since it was a first floor unit in a complex, and a former tenant had a dish outside. There was an outline of the mounting base and a line in the paint where the coax was installed previously leading up to a small hole which was siliconed, not in the back of the baseboard heat.
I cancelled the service when I got home from work and saw that garbage. I told them to send that guy out to get the equiptment too. When he came I showed him how bad it was, and he agreed.....
