[Linked Image from electricalphotos.com]
Handyman 1 (the previous homeowner) decided to replace an ungrounded receptacle with a grounded one, so he put a wire from a cable clamp screw to the new recept. OK, not code-compliant, but better than usual.
That is, if this house wasn't wired with NM Cable.
Thankfully inspector 2 (Falls Twp.) caught it and Handyman 2 (the "fixit so we can sell it" one) removed it.
Ian (Hope I'm doing this right) A.
Thanks to whoever moved this.
BTW, when I say "usual," I mean the usual thing he did in this house, put in a grounded receptacle in an ungrounded box without the jumper.
Still, that is if this house wasn't wired with NM.
Ian A.
Not a worry, Ian!
Why was it moved?
It failed the "three light" test so it was removed, and "replaced" with a new GFCI on the opposite side of the garage, tapped from a grounded living room circuit.
Ian A.
Originally Posted by JValdes
Why was it moved?
If you would like to start a photo thread for the Violation, Discussion or Nostalgia areas you can start it in one of the General areas (ie General, NEC, Non-US etc.) and it can later be moved by a Mod into the appropriate photo area.
Besides,
it means that all the photo threads are all kept together in one area of the site and makes things easier to find.
Oh, that "moved," I though he mistyped "removed..."
Ian (Wheres the coffee) A.
