458
11
Posts: 3,682 Likes: 3
Administrator Member
Crikey HC, You are having a good run of neat panels lately.
Well, I'll at least give them SOME credit for using SER cable to feed the sub panel!
---Ed---
It's PA, the capital of handymen with licenses.
Ian A.
Posts: 7,381 Likes: 7
Pictures being worth a thousand words...another reason for the Commonwealth to persue a uniform statewide construction code....licenses, permits & inspections.
Hmm, gotta love that "grounding" in the first picture! A few loops around the NM clamp should do it! Ian A.
Wait a minute! The sub is fed from the main panel. Then the white NM comes from the sub and goes back into the main?!? Aren't the electrons going to get dizzy? Larry C
