Bill39 Offline OP
What is the determining factor for when an injury is required to be put on the OSHA 300 log?
Say someone slightly cuts their finger at work and needs a bandaid?
Or someone with a bad back lifts a relatively light object at work but this causes another back injury that requires them to miss work. Does that need to be put on the 300 log?
If I recall correctly, "first aid" incidents need not be recorded. Events that result in a trip to the hospital, or time off work, do.
Bill,
Here's a PDF file on the 300 log.
Hope this helps.
O
