1 members (Scott35), 102 guests, and 11 robots.
plcnewbie #169994 10/22/07 10:51 PM
BigB Offline OP
Originally Posted by plcnewbie
Why not use MC home run cable
Stocking Sizes Color Codes:
Conductors 120 Volt Colors
6c black, black/silver, red, red/silver, white, white/silver
8c black, black/silver, red, red/silver, blue, blue/silver, white, white/silver
12c 3 black, 3 red, 3 blue, 3 white; each color numbered 1-3
16c 4 black, 4 red, 4 blue, 4 white; each color numbered 1-4
www.alliedtube.com/electrical-raceways/cable-systems/home-run-cable.asp
Looks like pretty nice stuff. I'll have to see if anyone carries it here in the Old Pueblo.
BigB #170008 10/23/07 09:54 PM
BigB Offline OP
Pulled em all today, no lube, 1 helper, super easy. Made my life easier.
BigB #170009 10/23/07 10:17 PM
So you filled the conduit to maximum capacity and didn't even use lube? You're a brave one.
SP4RX #170014 10/24/07 02:07 AM
Smurf is really a pretty easy pull if it is strapped tight and you don't have a sharp edge on the conductor stack.
It is slick inside and the corrigation means you have about half the surface area to create drag.
I know it is seen as an inferior wiring method and it is certainly not as tough as EMT but it may be as good as FMC or Carflex. I even think the UV protection is better than advertised/evaluated.
If someone is really interested I could probably pull out the piece that is on my boat and send them a sample to look at. This is Florida sun, 10 years with a south exposure and salt water.
The original connectors (split deal that snapped around the ENT) were certainly junk and that may be part of the bad rap. The same is true of the old RNC straps and conduit body covers. I had a Carlon guy tell me the listing standard did not require them to be U/V protected ... and they weren't.
gfretwell #170244 10/30/07 02:13 AM
I've ran miles of the stuff. Great for running a bunch of homeruns before they poor the slab.
Also, have used it as a grommet/raceway for getting romex around metal stud wall corners. wink
Luke Clarke
Electrical Planner for TVA.
Luketrician #170280 10/30/07 09:33 PM
I wish I had a pic of all the A/C condensing units fed w/ smurf at a apt. complex in Houston (between disco & unit).:(
