1 members (Scott35), 505 guests, and 14 robots.
Definitely looks like a 3 phase panel with a missing lug to me.
CH single phase panels use the same insulator and bus support, but the feed lugs are always on the 2 outside positions. Notice the burn marks where the lug used to be...
All 1Ø C-H panels I have seen use the center and right side for the lugs, if done that way it uses less copper for the bus stabs.
Admin #182702 12/07/08 01:43 AM
Originally Posted by Webmaster
The genius that installed the circuits apparently didn’t believe in ground wires because only 6 out of about 60 circuits actually have a ground wire connected to the grounding bus bar. All of the other circuits coming have been grounded through the metal conduit runs.
no wonder why the Panel looks so neat
-Joe
“then we'll glue em' then screw em'”
-Tom Silva
TOH
looks like quite a pile of dust or ashes? under the missing lug?
where is it normal to use yellow for nuetral?
