The ISP guy I was talking about insisted that the DSL modem could only be at the first jack
even with correctly installed filters.
Over here, the service provider normally sends a few in-line filters with the "free" modem package, with the usual instructions to use them on all telephone equipment. If I find problems it's often caused by somebody who either just missed one or more phones, or who didn't realize that things like dial-up modems and satellite receiver phone lines also have to go through the filter.
I usually try to persuade people to go with a single filter at the demarcation point to keep things simpler. These are our standard master jacks, which also serve as the demarc between TelCo and customer wiring:
http://www.austin-taylor.co.uk/pages/nte5.htmWe can get DSL filters which are designed to replace that lower removable panel and come with filtered and unfiltered terminals on the rear for extension wiring, like these:
http://www.adslnation.com/products/xtespec.phpNote that the unfiltered DSL connection is RJ11 configuration, the filtered voice jack is the standard BT431 phone connector.
As our standard voice extensions use white/blue for the line, plus one side of the white/orange pair for the bell feed, I usually run the unfiltered line on white/green then use a two-module extension jack assembly where DSL may be required.
