"low voltage lighting uses less electricity"
Ah yes...... I still remember an excellent example of that one. The existing lighting in the hallway of an old house was two standard 240V pendants which had already been fitted with 11W compact fluoros. They wanted them replaced with two strip systems, each carrying
three 50W low-voltage dichroic spots: "It will be cheaper to run."
Nothing would convince them otherwise.
"It's always safe to touch the white wire"
Well, for a very long time over here white was the color for B phase!
