by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#167515 08/14/07 09:04 PM
sudsy4 Offline OP
I'm installing 8 ft plug in fixtures in a large retail commercial building (28 per row). Is there any spec as to the spacing of supports?
Best answer may be:
Check mfg specs
or
Apply common sense.
8' fluor channel fixtures are surface mounted at 3 points; suspended at 2 points (each fixture)
It's a 'no definite' answer as the layout is vague by your description above.
ITO Offline
The only rule I know of is 110.3 (B)...well that and 110.12
101° Rx = + /_\
With hanging 8' strip lights I usually support the first one at both ends and the far end of each succeeding one.
Here is a job I finished last year, almost 600 fixtures.
That said I recently hung some 8' custom linear lights in offices and that jobs foreman had me do the same as I described above. IMO the fixtures being cast where to week for that and should have had three supports a piece for each fixture as they had been designed.
I guess what I am saying is follow Johns advice.....apply common sense. smile
Bob:
NICE....
BTW, quite a while back...like you said, 2 on the first; chase nip/ln thru end ko's, one on each additional.
I didn't want to write a novel on the many ways....
Now the 'old' 8' INdustrial type with the full reflector shade...nice old heavy mag ballast, and a housing made from real live steel, not recycled Pepsi cans (man's fixture), that was a definite 'two chainer'.
Back to my serious mode....any shot to get good old common sense into the NEC??
Stay safe
sudsy4 Offline OP
Thanks for the input everyone. I agree on the 2 on first fixture then one a foot or so from the end of all the rest; however, bar joists don't fit that senario. I guess my actual question was can you miss a hanger on a fixture or must you have a support on every fixture? Checked manufactures specs, told me nothing. The store is a Wal-Mart Superstore.....many many fixtures.
sudsy4 Offline OP
Thanks for the pics...nice job
Bar joist locations not 'matching' a place for a support are solved by bridging b'twn bar joists with strut, or another suitable alternate.
What about the plans/specs? Most, if not all will provide a detail on the REQUIRED method of installation by the Architect/Engineer of record.
Your 'client' is not a small operation, so you should have details available, or submit an RFI.
I would not skip a support, as John mentioned you need to come up with a way to get a support where you need it.
In my picture above out of over 600 supports only a few actually land on a truss. If you notice the fixtures are diagnal...a major pain in the rear.
Anyway we used these from Caddy...
[Linked Image from erico.com]
To install most of them you use this tool...
But before we got started I sent an RFI to the engineer asking if this method of supporting from the deck was OK. He approved it and away we went.
I can tell you these are very strong.
BTW, also the fixtures in the above photos are joined with factory couplers with 4 tek screws added per coupling to ensure the fixture could not pull apart and drop.
How does this grab the deck?
