1 members (ComputerWizKid), 331 guests, and 28 robots.
#165005 06/16/07 01:48 PM
Sixer Offline OP
...done some wiring where after it was completed you've second-guessed yourself....even years later?
I confess that about 10 years ago I did a panel change where the old panel didn't have a main breaker (it was a 100 amp panel). The new panel had a 100 amp main, and a long time after it was installed I started thinking that possibly the feeders were #4 (good for 85 amps) and not the #3 that I thought they were. The era of this home is making me think that it was a 70 amp service as I've since discovered that size of service was very common in that time. Now I always use my wire mike to verify the size if I'm unsure.
To this day I've sometimes wondered if I did that job correct. At least now the panel does have a main breaker although it may be oversized by 15 amps. With the size of the home and the loads connected, I'm confident that it won't exceed the rating of the main feeders. BTW, the house is still standing laugh
Just wondering if any of you have ever done some wiring and second-guessed yourselves after the fact? Would be interested in your responses.
Sixer
Z
I'm sure we all have some skeletons in our respective closets.
Except for me... I never make mistakes smile
Sixer Offline OP
I was hoping to catch you on a spelling error there Zapped laugh
Sixer
We are allowed to use #4 cu for residential 100 amp feeders (from 310.15(B)(6) to the main panel or to a sub panel, as long as it is a lighting and appliance panel, not to a shop or a tankless water heater etc. Of course I am not in Canada.
Z
lol sixer...
e57 Offline
Sure, all those "do what you're told" moments, the times it was said to you, and the times you said it... Mean someone was questioning something... I think I man enough to listen, (Sometimes) and I'm sure when I was under someone else they gave some thought to the question at hand.
