Scott35 Online Happy OP
Topic: Some pictures of RW and TW Conductors
Here are a few images of # 8 Solid Copper Conductors with RW and TW type Insulation.
Image #1: Overview of both types of Conductors - the "RW" has Black Insulation, and the "TW" has White Insulation.
Image #2: #8 Solid Copper with RW Insulation.
Image #3: #8 Solid Copper with RW Insulation - close up.
Notice the Tinned Copper.
Image #4: #8 Solid Copper with TW Insulation (White).
Image #5: Close-up of #8 Solid Copper with TW Insulation (White).
Note the printed text.
Imaging pulling Three of these bad boys through a long run!
Somewhere in my "Archives" I have some Solid #6 and #4 Insulated Copper Conductors - imagine pulling those puppies!!!
eek
Scott
I'm fairly certain that tinning of conductors keeps copper and rubber from chemically reacting, preventing corrosion of the copper conductor.
Scott - how have you been!!! smile
It sure has been a long time since I saw a posted message with "Bjarney" attached!
Hope everything is going OK in the "West Southern Inner Northeast ... "
Just an FYI, my E-mail address has changed (again), and is no longer within the "Pacbell" domain.
Here is a Phonetic version of one address, which messages will actually be accepted by the Mailbot, and not bounced back with SMTP Error 550:
designer at setelectric dot net
(remove the spaces between words, swap the word "at" with the "At" symbol [Shift + "2"], and make the "Dot" a _Dot_)
Send me a message when you get an urge to speak geek!
Scott
