260
20
I will be the first to tell you I don't know everything. I don't have much experience with K&T and I am looking at doing a service upgrade on a house that has some K&T, not all just a couple of circuits. It looks like the circuits that are K&T are the orignal general use circuits to the house. The K&T wiring is in good shape, bendable, no cracks, it doesn't appear to have been over heated. The home owner doesn't want to open up the walls, so I was going to cut out half of the K&T circuit, there are no outlets on this section, set a 4x4x2 non-metallatic junction box and bring the remaining K&T in on opposite sides of the box, then tie in with romex and run back to the new panel. I ran this by a friend of mine at the local inspection office and he saw no problem with it, as long as the existing K&T was it good shape. I read this board alot and was wondering what was your thoughts or suggestions.
Rowland
just bring the old K&T in through seperate knockouts in a NM box and you should be good to go, most areas have some form of a "grandfather clause" that covers stuff like this. I would check behind the lights though, a lot of old lights on K&T hlack boxes, and have crispy wires from overlamping, just a CYA (cover your behind)
oh, and welcome to the board!
-Will
Look in the NEC, not sue what article but you might need to protect the existing K&T with a GFI. Ran into this about 8-9 yrs ago and that was the solution then, not sure if NEC has changed since.
I was planning on bringing the K&T in through different knockouts, in fact I am planning using one of those NM junction boxes that you drill your own holes in and I was even going use some rubber groments in the holes. Thanks for the input. In my area K&T is taboo, everyone says rip it out. The way I look at it, it has been that for 100 years and if it is good shape why rip open walls and ceilings.
Rowland
The artical in the NEC for K&T is about 2 pages long and just says splices will be in an approved manner and wire will be in accordance with 310. I and my friend found nothing about GFCI, but I will double check. Thanks Rowland
Posts: 9,923 Likes: 32
The only way to get to GFCI being required on K&T is if you serve a grounding type receptacle and no ground present
K&T is still an approved method of wiring, however, in the last few months we have been getting calls from home sellers, it seems the buyers of homes, that have K&T can not get insurance for them, and are requiring rewire before insuring.
Hi Rowland, u can use solder on the K&T and tape it up just as was done on all the joints and taps. It is one of the approved mean, and is simple. I have been out on many calls from realtors, to remove wirnuts and other splices from K&T. Inspectors here seem to like this approch.
Ob
Where the old K&T enters existing boxes, there should be an additional sleeve on the wire. I always have a couple of pieces of this sleeving on hand when working with K&T for entry into new boxes to protect the wire.
As for insurance, we have the same issue here as what Les said above. Once a house with K&T is sold, insurance companies give a fixed period of time to have it replaced, otherwise the homeowner can't get insurance.
Sixer
The same is true here, as well. The last job I did the homeowner was required replace the K&T within 30 days after closing.
