by HotLine1 - 04/23/24 02:17 PM
0 members (), 231 guests, and 11 robots.
Some pics of stuff from my collection.
cschow (Chris)
Porcelain lampholders:
Despard plug and switches and a CrouseHinds porcelain outlet. Not sure of the application of it:
All these fixtures came out of the same house. The lumiline light still works. It was in a closet:
Rotary and pushbutton switches. Also an unusual old brass toggle wall switch with plate:
Lighted switch plate with a 1945 advertisement for it:
Thanks for sharing these with us Chris. Some interesting stuff there! smile
Ah.... A double T-slot receptacle again. Have a look back through the Nostalgia area; we've had several discussion about the use and development of these.
Similar switches were once common in some British applications -- Different mounting arrangement to suit our different boxes and plates, but the same style of toggle. They were fairly common for multi-way switch banks on 1940s/50s installations in schools, commercial buildings, etc.
K
Positively lethal looking by today’s standards.
In pict 4, what type of cable is used to supply the switches?
der Großvater
The Crouse-Hinds outlet was probably for surface-mount conduit installations -- like a garage, workshop, store, factory or other such place?
Now you have to buy all those parts separately. smile
The triplex Despard outlet is just like ones in my mom's house. It's usually a single molded piece instead of 3 devices on a metal frame. The ones in my mom's house are in excellent shape and grip plugs well. Only downside is that it doesn't accept 3 prong plugs with grounds.
It turns out that the Despard cover plate mounting screw hole locations match up exactly with Decora plates. You could carefully cut a Decora sized rectangular hole in a Despard cover plate to make it fit say a GFI outlet. If someone wants all the cover plates to match existing ones in the room...
Yeah, but by now that plastic is probably all brittle from age. Good luck cutting the hole without having the plate shatter. frown
P.S.: The Lumi-Lite plate is "t3h win". cool
Just standard old knob and tube wire.
The toggle switch came out of a basement entrance and it was actually set into a pocket in the rock, so it looks a little beat up.
smile
Was a surface mount. There are no mounting screws for it, so it was supported by the ridgid conduit. It tilts down about 30 degrees when mounted. Nice feature IMO.
More pics on their way.
Can you post a picture of the back of the Lumi-Nite Plate? I want to see how it connects to the power. Thanks
Theres always enough room in the junction box.You just need a bigger hammer
I will submit it in my next batch of pics. I was looking at how it was powered, and there are no diagrams or instructions on it. The back has 2 black leads with spades. I assume they connect to the screws on the switch itself. The leads weren't hooked up when I removed the plate.
There are two brown wires that get tied into the travelers. It contains a neon lamp inbedded in resin.
