You go ITO! Also, AIC ratings should be shown, and calculated. A lot just plug in high AIC ratings that you know aren't needed. Loads, wherever listed, should clearly show watts or amps. Details are good, but the plans don't need to teach Electrical 101. Make sure the size of print can be read in realtime. If you pass the drafting off to someone, check their work; you can almost see when someone passes it off. And PLEASE (even though it is usually not your call) don't put plans on a paper size that won't fit standard drafting tables!!
