Washing machines in North Am are usually split phase or shaded pole single phase 120 volt motors. Some are capacitor start with a start and run winding.
I am wondering what a 6 phase DC motor is. Could it be a 6 pole DC motor? Why DC? Why would anyone put a motor with brushes in a washing machine? Motors with brushes and commutators are usually series wound AC or Dc motors like in power tools Some work AC,DC and would be a universal series wound motor.
You are probably right when you say it is a 6-pole machine. That makes more sense to me anyway
I have found the difference between US machines and European machines is that the US consumer prefers top loaders where as Europeans prefer side-loading machines. It takes more initial effort to start side loaders than top loaders so you can get away with lighter motors in top loaders. The universal motor (the one with the brushes) has a higher stating torque than an induction motor.
DC motors run more efficiently than AC motors. Due to losses in power becouse AC changes frequency. Where as DC does not change frequency from + to - there is no losses.
Imagine the sine wave of both AC and DC voltage. Now take the AC sine wave and flick the bottom half up so you have a series of peaks and troughs in a row. Because AC takes time to go from the 0 up to max voltage and back to 0 we loose some useful power. To work out how much we have lost we multiply our peak voltage by 0.707 this now gives us our useful AC voltage (known as RMS)
Try this
300Watts @ 120 volts = 2.5 Amps
300Watts @ (120 volts x 0.707) =?
Therefore 300Watts @ 84.84 Volts = 3.5 Amps
So you can see (I hope) that when using AC power we need to draw more current to do the same work as DC power. Higher current means what class?
