Our operation is retooling to start using quad-shield RG-6 and compression connectors instead of crimp-style. I purchased a cablepro PSA59/6 stripper to try it out and am not happy with it because I can't get it to strip more than the cable jacket. This means that when doing the terminations you have to spend a bunch of time folding back the shield layers before you can put the connector on. Are there any strippers that you can adjust to cut through all of the shields except the inner layer of foil? Does anyone have any additional advice for making fast and clean terminations on quad shield RG6?
-Hans
