i'm not following you. if a jman and an apprentice are billed at the same rate, how does that work out?
for example. both billed at $100/hr. Jman takes 4 hrs = $400 labor. Less skilled apprentice takes 5 hrs = $500 labor.
am I missing something?
Erik,
Are you looking at this from the perspective of Time and Materials billing or from the perspective of time required vs cost to do the job?
If I estimate that it will take 4 hrs to install a new smoke detector, I am confident that a jman can install the new cct and smoke detector in 4 hrs... therefore, he will cost me $40 per hour times 4 hrs or $160.
If I have an apprentice go out and do this job, based on his experience, he will take say 6 hrs to accomplish this same job, but his hourly cost to me is approx. $27 per hour times 6 hrs or $162.
The apprentice rate should represent his/her skill level as compared to the jman. The actual hours required for the apprentice to complete the project should work out to the same dollar cost (plus or minus) to the cost of the jman to complete the project.
Therefore, when I bid a project, I don't differentiate between apprentice and jman, I quote jman rate and realize that the apprentice will take longer. I do realize that you can bid projects with jman rate and hours and apprentice rate and hours, however, the majority of my projects are smaller so it is quicker to handle the hours the way that I do.
