Well, over here ceilings consist of 10mm
Gib(drywall), it is held up by runners @ 450mm or 600mm, these run perpendicular to the roof trusses, held in place by the chords on the trusses.
If you want to know more about how this Gib-board is installed, check out gib.co.nz.
